If you plan to add more later down the road, then go for the single 8GB stick
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/489994-ram-help/#findComment-6572179
Hi guys, i gonna buy 8gb of ram, my cuestion is
Buy two HyperX 4gb 1866 or one HyperX 8gb 1866? I think that is better one of 8, becuse later i can buy another one :D
you just answered your own topic
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/489994-ram-help/#findComment-6572251
yes, but with logic, i noob with pc's
get 1x8 if you want 16gb in the future.
Old Rig
https://linustechtips.com/topic/489994-ram-help/#findComment-6572696
