So i have a xfx 6850 that for what ever reason wont fold, cpu folding is fine n dandy and thats in my main rig and another note is that the gforce g210 i have in my folding rig always says unknown PPD which is starting to bugg me now, but again cpu folding is fine, iv not been folding for long so any help will be appricated in advance thanks guys
Intel Core i3 530 Clarkdale @ 4.82 Ghz ! :D 64.5% O.C !
Daily @ 4.2 Ghz ;) 43.8 % O.C
Intel® Core™2 Duo E6320 Stock @ 1.86 Ghz --->> OCed to 2.97 Ghz 60 % O.C !
https://linustechtips.com/topic/48966-xfx-6850-not-folding/
Do you have your Folding percentage bar set to full?
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/48966-xfx-6850-not-folding/#findComment-651420
On the Advance view, go into the Log section, check the box for the Slot that corresponds to your GPU and post the log here so we can see what it is trying to do. As for your 210 - ya, some older ones never get a PPD estimate done for some reason.
You can run GPU-Z though to verify the GPU load is high to show that it is indeed folding.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/48966-xfx-6850-not-folding/#findComment-651857
yeh i do
i have checked with gpu-z and its up at like 85% + almost all the time, my maid reason for questning is will it still contribute to my PPD score or not ?
 i am not at home at the moment so shall post the log screen when i am
https://linustechtips.com/topic/48966-xfx-6850-not-folding/#findComment-663266
18:00:05:Saving configuration to config.xml
18:00:05:<config>
18:00:05:  <!-- Folding Core -->
18:00:05:  <cpu-usage v='75'/>
18:00:05:
18:00:05:  <!-- Folding Slot Configuration -->
18:00:05:  <power v='full'/>
18:00:05:
18:00:05:  <!-- Network -->
18:00:05:  <proxy v=':8080'/>
18:00:05:
18:00:05:  <!-- User Information -->
18:00:05:  <passkey v='********************************'/>
18:00:05:  <team v='223518'/>
18:00:05:  <user v='motman0591'/>
18:00:05:
18:00:05:  <!-- Folding Slots -->
18:00:05:  <slot id='0' type='GPU'/>
18:00:05:  <slot id='1' type='CPU'/>
18:00:05:</config>
18:00:05:FS01:Shutting core down
18:00:07:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
18:00:08:WU01:FS00:News: Welcome to Folding@Home
18:00:08:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
18:00:08:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
18:00:09:WU01:FS00:News: Welcome to Folding@Home
18:00:09:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
18:00:09:ERROR:WU01:FS00:Exception: Could not get an assignment
18:00:14:WU00:FS01:0xa4:Client no longer detected. Shutting down core
18:00:14:WU00:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
18:00:15:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
18:00:16:WU00:FS01:Starting
18:00:16:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tom/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 4400 -checkpoint 15 -cpu 75 -np 3
18:00:16:WU00:FS01:Started FahCore on PID 4080
18:00:16:WU00:FS01:Core PID:1460
18:00:16:WU00:FS01:FahCore 0xa4 started
18:00:16:WU00:FS01:0xa4:
18:00:16:WU00:FS01:0xa4:*------------------------------*
18:00:16:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
18:00:16:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
18:00:16:WU00:FS01:0xa4:Preparing to commence simulation
18:00:16:WU00:FS01:0xa4:- Looking at optimizations...
18:00:16:WU00:FS01:0xa4:- Files status OK
18:00:16:WU00:FS01:0xa4:- Expanded 1168858 -> 3134204 (decompressed 268.1 percent)
18:00:16:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=1168858 data_size=3134204, decompressed_data_size=3134204 diff=0
18:00:16:WU00:FS01:0xa4:- Digital signature verified
18:00:16:WU00:FS01:0xa4:Project: 8704 (Run 592, Clone 0, Gen 24)
18:00:16:WU00:FS01:0xa4:Assembly optimizations on if available.
18:00:16:WU00:FS01:0xa4:Entering M.D.
18:00:22:WU00:FS01:0xa4:Using Gromacs checkpoints
18:00:23:WU00:FS01:0xa4:Mapping NT from 3 to 3
18:00:23:WU00:FS01:0xa4:Resuming from checkpoint
18:00:23:WU00:FS01:0xa4:Verified 00/wudata_01.log
18:00:23:WU00:FS01:0xa4:Verified 00/wudata_01.trr
18:00:23:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
18:00:23:WU00:FS01:0xa4:Verified 00/wudata_01.edr
18:00:23:WU00:FS01:0xa4:Completed 6210 out of 1500000 steps  (0%)
18:02:44:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
18:02:46:WU01:FS00:News: Welcome to Folding@Home
18:02:46:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
18:02:46:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
18:02:47:WU01:FS00:News: Welcome to Folding@Home
18:02:47:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
18:02:47:ERROR:WU01:FS00:Exception: Could not get an assignment
https://linustechtips.com/topic/48966-xfx-6850-not-folding/#findComment-673319
Looks like you may be having an issue getting to the Work Server - most likely because of their server issues.
Also, try deleting the work queue - In FAH, look at the number for the Slot your GPU is in. Then shut down folding.  go in Start -> FAH -> Data Directory - in there you will see a work Folder. Delete the one that corresponds to the Slot number for you GPU - typically 0, or 1...
Restart folding...
https://linustechtips.com/topic/48966-xfx-6850-not-folding/#findComment-675383
