fx-6350 cooler upgrade?
jakejake2115
So I built a budget pc a while back with a 960 and a 6350, but the stock cooler on the cpu is loud as hell and very annoying, is there any cheap alternatives that are quiet but will fit in a corsair spec-03? And also what differences will I see in general pc use and gaming if i oveclock this cpu? Thanks
Fx-6350 | Asus Strix GTX 960 2gb | Asus R5a97 2.0 | 2x4gb Vengeance ram | Corsair CX750 | Corsair Spec-03 | Seagate 1tb 7200rpm HDD | Sandisk 120gb SSD |
cooler master hyper 212 is good, but if you need something smaller the Phanteks PH-TC12LS is good.
The fan it comes with is loud though.
Noctua has a great low profile cooler and so does BeQuiet
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
http://pcpartpicker.com/part/corsair-cpu-cooler-h55
