Hi so i just updated my gaming rig:
I put a Corsair Cx750W instead of a CM 550w GX and a nvidia 760 msi OC instead of a Sapphire HD5750.
I also added a CM Excalibur fan in input.
I used an AMD software to remove the old drivers.
Since i have the new graphics card sometimes i hear a really acute noise, it's not a coil whine since it's totally random and it doesn't occur only when the system is stressed.
This sound is really rare and sounds like a car breaking(that acute noise you hear sometimes when car breaks).
I had no main issues since yesterday: I run a render in Blender and the PC froze, the mouse was still moving, but if i clicked something, pressed CTRL+ALT+CANC or the power button, nothing heappened.
I had to unplug the pc to turn it down.
Then my pc showed via windows message this:
Download and install the driver for your power management system
I clicked on their link and it downloaded me a file called: AMDCoolnQuiet_Utility_V21801_XPVistaWin7
Should i install it? It looks a bit strange to mee because it's AMD's and i have no AMD components.
By the way my specs are:
I7 860@2.8ghz
MB Asus p7H55 m pro
6 gb kingstone 1333mhz
MSI 760 OC
Corsair CX 750w
CM Excalibur fan
Intel stock cooler
CM Ellite 333 case
Thank you
https://linustechtips.com/topic/48823-power-management-driver-issue/
