3 pin into a 4 pin?
bhcool12
Is it possible for me to plug a 3 pin fan connector to a 4 pin cconnectoer?
Yes
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
Yes. The extra pin is for PWM fans. Two and three pin fans will work just fine. The pin functions are the same between 3 and 4 pin connectors.
If you mean plug a 3 pin fan into a 4 pin motherboard, then yes you can. Some of the new motherboards are getting lazy with voltage control(ie: leaving it out), so your fan might just spin at full speed.
ok thx. I was a bit worried there lol
Yes, the 4th pin is for PWM fans with a 4 pin connector.
And no, you don't need to worry about what 3 pins it gets plugged into, there is a plastic tab on the connector that keeps you from putting it in the wrong spot.
