So I just bought 16 gb Corsair Vengeance 1600mhz ram, but it only runs at 1333mhz? What can I do?
Did you set it to the correct speed in the BIOS?
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
I've enabled XMP n stuff but on the left side it says 1333mhz and on the right 1600mhz
Soooo...idk. I don't really know much about RAM
What CPU and motherboard?
I have 1600MHz RAM, but it only runs at like 1400MHz with my Pentium G3220 and Asus H81M-A, and at 1333MHz with my previous FX-4130 and Gigabyte GA-78LMT-USB3.
