Do I need a fan splitter?
Savir
This is my mother board: ASRock H97M Pro4 LGA 1150 Intel H97
Case: NXZT S340 ATX Mid tower
I was planning to use these fans http://www.amazon.com/Corsair-Series-AF120-Edition-Airflow/dp/B00F6S10KK and the 2 fans that come with the case in my system.
Do I need a fan splitter? like this?
http://www.amazon.com/SilverStone-Technology-Sleeved-Splitter-CPF01/dp/B00B46XKKQ/ref=pd_sim_147_6?ie=UTF8&dpID=31CHO8viz1L&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=037Q7GVPYZBW9T1ZHHZ9
or does my motherboard have enough fan slots? I'm kinda confused which specs tell me this. Plz help
-snip-
You'll need a splitter.
Other systems I've built:
Your motherboard can handle 3 case fans + 1 cpu fan. So a splitter is needed for 4 fans.
You can check the manufacturer's website or look at a pic of the board,you will see how many fan connectors the board has
Ok so the splitter I linked will work correct?
Yes it will.
Yes.
Yea a fan splitter is needed in the situation.
i personally wouldn't be connecting 2 fans to 1 fan header on the MOBO. Dat power draw
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
hey guys, I have a qyestion: what is the purpose of a fan splitter? the fan header only works for one pwm fan, so if you connect two it wouldn't work.
you can always connect directly to psu. am I missing something?
case:"accelerated"Therlmatake VA8000BWS Armor psu:EVGA Supernova G2 750w board:Asus M5A99 FX Pro R.2
cpu:AMD FX 8350 ram:2x8gb Corsair Vengeance Pro 1866mhz gpu:Sapphire Nitro R9 380  4gb
ssd:Samsung 850 EVO 250gb hdd: 2x1tb WD Caviar green cpu cooler: Coolermaster Hyper 212 EVO
Fan headers can support more than 1 fan. Usually 2 is max, SOMETIMES 3 (2 is safe)
Both fans can be controlled off the same header.
Silverstone FT-05: 8 Broadwell Xeon (6900k soon), Asus X99 A, Asus GTX 1070, 1tb Samsung 850 pro, NH-D15
Resist!
 from what I can see in pictures your mobo has 5 fan headers.
Both fans can be controlled off the same headers.
I really don't know about that, because for example the fan controlling interface(I use ai suteII)"sees" the fan headers from the mobo and controls them. if in chassis fan1 for example there are two fans connected I'm not sure what will the interface get. if you tried it and works that would be very interesting
if both fans are the same and they are plugged in (ie in my case I have 2 NFF12 intakes and 2 NFA14 in push pull on a rad)... One set of fans are plugged into one header to control at the same speed for both. The other set are on another header to control at the same speed for both. So i guess in a way you are limited in that sense, but still the fans are controlled
Resist!
nice! it's a really good solution then and I will try it some time!
