So I hope all you guys are having a nice day! :)
I have already built a PC but that was months ago, so I want to build a Mini ITX PC.
I already selected all Parts, but I don't know if all the LED's and fans will fit and connect.
Here are the Parts;
Case:
Corsair Carbide Air 240 (Cube, Schwarz)
GPU:
ASUS GTX-660 Ti DirectCU II 2GB GDDR5, PCI-E x16 3.0 (2.05GB)
CPU:
Intel Core i5 6500 (LGA 1151, 3.20GHz)
RAM:
Corsair Vengeance LPX (2x, 4GB, DDR4-3200, DIMM 288)
PSU:
Corsair RM Series RM550 (550W)
LEDs:
2X PHOBYA LED-Flexlight HighDensity (Red, 36, 300mm)
Fans:
Corsair AF120 Quiet Edition, Rote LED, 2 Pack (120mm)
Mainboard:
MSI Z170I GAMING PRO AC (LGA 1151, Intel Z170, Mini ITX)
CPU Cooler:
Raijintek Triton 240mm
So, my Question is if I can actually build this RIG. My main problem is, I don't know if I have enough fan ports and where do I plug in the LEDs? (7 Fans or 5 Fans, 2 300mm LEDs) I know how to build the RIG itself but I have no clue where to plug in all those fans and LEDs.
I apologize for my bad English, I'm from Switzerland. :)
Greetings - Luca Miani
PCPartpicker List: http://pcpartpicker.com/p/fgxQkL
https://linustechtips.com/topic/487263-will-this-build-work/
Plug fans into motherboard or if case comes with fan hib. Also why a 660Ti? Assuming you already own it correct? Also use PcPartPicker.com as it usually,is,pretty good if something is not compatble.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/487263-will-this-build-work/#findComment-6539709
The 660 Ti just looks dumb next to the skylake CPU.
Probably just go get a R9 390.
I don't think you have any issues with the fans, but if you ever need more fans than the motherboard can hit on, then a pwm hub??<--Correct this for me if i am wrong.
https://linustechtips.com/topic/487263-will-this-build-work/#findComment-6539711
Yes, I already own one. So I thought about just using it for this build, I mean I will safe some money and its still upgradeable. And it's just a LAN PC, I won't work with it.
https://linustechtips.com/topic/487263-will-this-build-work/#findComment-6539731
https://linustechtips.com/topic/487263-will-this-build-work/#findComment-6539732
Then it will do, but prepare to upgrade it in about 1-2 years.
https://linustechtips.com/topic/487263-will-this-build-work/#findComment-6539744
Alright makes sense. Can always add like a 380 or 390 later dowm the road. Also as stated, put this in pcpartpicker.com
https://linustechtips.com/topic/487263-will-this-build-work/#findComment-6539751
