Hi, so i need to create a database for my college assignment and my mind has gone blank on what to call certain items within the gpu the card i will be using for the example is:
https://uk.pcpartpicker.com/part/msi-video-card-gtx970gaming4g
my database will include:
CoreClock[1.14Ghz]
series[900]
memory[4gb]
chip manufacturer name[Nvidia]
card manufacturer name[MSI]
Brand{Gefroce}
My main question is what is the 70 bit of the 970 called? as its part of the 900 series but the 70th {BLANK}
and is the Brand correct with being geforce/AMD? or is there a better name for this?
Please ask questions if you need to
thank you so much to anyone who helps!
https://linustechtips.com/topic/487198-need-help/
I don't understand your question you mean the 70 behind the 900 (970)?
If that's the case then I know the answer. the number behind the 500,600,700 and 900 series means for what kind of purpose it is (what kind of range). 950 and 960 are low-range, 970 and 980 ar high-end and GTX 980ti and GTX Titan X are enthushiasts cards.
https://linustechtips.com/topic/487198-need-help/#findComment-6538705
GPU Model?
Also you spelt Nvidia wrong. Here's how you would pronounce it N-VID-Eye-Ah
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/487198-need-help/#findComment-6538713
GPU Model?
so my mate has suggested i call it the 900{series} and the 70{sub series} but my new question is about the geforce what would you call this in relation to the card/
https://linustechtips.com/topic/487198-need-help/#findComment-6538742
GeForce is more designed for gamers and the Quadro series is more designed for workstation like drawing and other stuff like that.
https://linustechtips.com/topic/487198-need-help/#findComment-6538747
but what would you call it if you had to designate it a name in a field exmp:chip manufacturer name:Nvidia
{BLANK}=geforce?
https://linustechtips.com/topic/487198-need-help/#findComment-6538763
