PC help
Go to solution Solved by stconquest,
If it's required then yes, but I'd just like a list that ships to Aus, is silent enough so my microphone doesn't pick it up and is under 2k, thx.
My original build is exactly that.
I made a balls to the wall build here, it is ready for a second GTX 980Ti if you just love spending money:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($517.00 @ CPL Online)
CPU Cooler: CRYORIG R1 Ultimate 76.0 CFM CPU Cooler  ($99.00 @ PCCaseGear)
Motherboard: Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard  ($239.00 @ CPL Online)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($189.00 @ Umart)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($243.00 @ Centre Com)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($1069.00 @ CPL Online)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($139.00 @ PCCaseGear)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($279.00 @ CPL Online)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($129.00 @ CPL Online)
Total: $2903.00
Generated by PCPartPicker 2015-11-18 17:56 AEDT+1100
I cut $40 off of the first build, it is $2001:
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler  ($45.00 @ PCCaseGear)
Motherboard: Gigabyte GA-Z170-HD3 ATX LGA1151 Motherboard  ($185.00 @ IJK)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($155.00 @ IJK)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($134.00 @ Centre Com)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($69.00 @ Centre Com)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($509.00 @ Umart)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($119.00 @ Umart)
Total: $2001.00
Generated by PCPartPicker 2015-11-18 18:00 AEDT+1100
I seriously recommend the Phanteks Enthoo Pro.  It comes with large fans(quiet) and is very well built.  I consider it the best value at it's price range.
This is a good case, but you are spending $50 solely for aesthetics:  http://au.pcpartpicker.com/part/nzxt-case-can450ww1
http://au.pcpartpicker.com/part/nzxt-case-can450wm1
I can link you videos all day long, but:
https://www.youtube.com/watch?v=k1Q8ksRI1Eo
https://www.youtube.com/watch?v=9zQXFkzZ1Ac
https://www.youtube.com/watch?v=wgyX7-YckeI
Thanks for he videos :)
Also, with the cases including the fans wouldn't that exclude the fans in the part picker untimately bringing down the price anyway?
https://linustechtips.com/topic/487128-pc-help/page/2/#findComment-6538114
You are welcome.
You lost me on the fans thing.  The reason I like picking cases like the Enthoo Pro is that it comes with enough airflow to get you started.  A big 200mm front intake fan, and a 140mm in the rear (exhaust).  The bigger the fans, the quieter it can be.
https://linustechtips.com/topic/487128-pc-help/page/2/#findComment-6538126
You are welcome.
oh, sorry, I thought the original case didn't include fans, thanks for all your help, I'll try and grab this for Christmas and build it (I'll tell you how it goes) thank you so much for all ur help!
Would the alien looking cases be as silent as the original or would it be a bit louder? (I just can't stop asking questions can I? :P)
https://linustechtips.com/topic/487128-pc-help/page/2/#findComment-6538131
Can I just ask what you mean by this? I don't quite understand how it can get messier inside cities
Also, is this design loud? Because I'm planning on doing yet on it
Fallout 4 uses Gameworks and therefore is immediately optimised for NVIDIA cards such as the GTX 970. The game does experience quite a drop in fps when in combat or when entering a city on a 390 however.
Just turn off Gameworks features such as god rays and it should run fine. Or maybe when AMD gets around to upgrading their drivers.
https://linustechtips.com/topic/487128-pc-help/page/2/#findComment-6539579
