PC help
Go to solution Solved by stconquest,
If it's required then yes, but I'd just like a list that ships to Aus, is silent enough so my microphone doesn't pick it up and is under 2k, thx.
My original build is exactly that.
I made a balls to the wall build here, it is ready for a second GTX 980Ti if you just love spending money:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($517.00 @ CPL Online)
CPU Cooler: CRYORIG R1 Ultimate 76.0 CFM CPU Cooler  ($99.00 @ PCCaseGear)
Motherboard: Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard  ($239.00 @ CPL Online)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($189.00 @ Umart)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($243.00 @ Centre Com)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($1069.00 @ CPL Online)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($139.00 @ PCCaseGear)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($279.00 @ CPL Online)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($129.00 @ CPL Online)
Total: $2903.00
Generated by PCPartPicker 2015-11-18 17:56 AEDT+1100
I cut $40 off of the first build, it is $2001:
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler  ($45.00 @ PCCaseGear)
Motherboard: Gigabyte GA-Z170-HD3 ATX LGA1151 Motherboard  ($185.00 @ IJK)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($155.00 @ IJK)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($134.00 @ Centre Com)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($69.00 @ Centre Com)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($509.00 @ Umart)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($119.00 @ Umart)
Total: $2001.00
Generated by PCPartPicker 2015-11-18 18:00 AEDT+1100
Here's the specs I'd you to rate in gaming comparison and how many fps I'd expect from the better PC on games such as GTA V, Fallout 4 essentially high graphics games.
First PC
Specs:
-Corsair Obsidian 250D Case
-Intel Core i7 4790 CPU
- ASUS Z87I-Plus Motherboard
-Corsair RM-750 ATX Power Supply
-16GB DDR3 1600Mhz Memory
-2TB 7200RPM HDD
-DVD-R/RW/CD-R/RW
-Microsoft Windows 8.1
-Corsair H100i Liquid Cooler
-Nvidia GTX 760 2GB
This is the second PC
Specs: -Corsair Obsidian 450D Case
-Intel Core i7 4790K CPU
- ASUS Z97-Deluxe Motherboard
-Corsair RM-1000 ATX Power Supply
-2TB 7200RPM HDD
-DVD-R/RW/CD-R/RW
-Microsoft Windows 8.1 -Samsung 250GB 840 SSD
-Nvidia GTX 780Ti SC 3GB
I would also like to know how you'd rate this among pcs such as Alienware, is this better or worse and how much would you price this computer at?
Thank you very much :)
https://linustechtips.com/topic/487128-pc-help/
The first costs just under 2000 and the second is barely under 3000, it's an Australian based company, do you have any recommendations then?
EDIT
the company's called Phoenix PCs
Here is an example of a better way to spend the money:
Total: $2041.00
Generated by PCPartPicker 2015-11-18 17:15 AEDT+1100
https://linustechtips.com/topic/487128-pc-help/#findComment-6537891
I know that building a pcs way better then prebuilt but I'm looking for a prebuilt since I don't have the time/equipment to build my own
It's really easy to learn. There are plenty of videos out there where you can learn the ins and outs of pc building.
https://linustechtips.com/topic/487128-pc-help/#findComment-6537917
Here is an example of a better way to spend the money: PCPartPicker part list / Price breakdown by merchantCPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($517.00 @ CPL Online)CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler ($45.00 @ PCCaseGear)Motherboard: Gigabyte GA-Z170-HD3 ATX LGA1151 Motherboard ($185.00 @ IJK)Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory ($155.00 @ IJK)Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($243.00 @ Centre Com)Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card ($509.00 @ Umart)Case: Phanteks Enthoo Pro ATX Full Tower Case ($139.00 @ PCCaseGear)Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply ($119.00 @ Umart)Operating System: Microsoft Windows 8.1 OEM (64-bit) ($129.00 @ CPL Online)Total: $2041.00Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-11-18 17:15 AEDT+1100
Ah well, I might try that then, any idea how many fps I'd expect from this design and any videos I can use to help me with building it?
Much appreciated.
https://linustechtips.com/topic/487128-pc-help/#findComment-6537933
Much appreciated.
It depends on the game.  That PC is on the higher end of the performance spectrum.  Expect a solid 60 FPS in every game with the most demanding titles being graphically tuned to stay at 60FPS.
Just for fun:
https://linustechtips.com/topic/487128-pc-help/#findComment-6537951
Ok, what about GTA V and Fallout 4? (Sorry I'm dragging this out a bit, I'm really happy with the service tho)
And can I have a video to use as reference?
https://linustechtips.com/topic/487128-pc-help/#findComment-6537959
Fallout 4 has issues, but the 390 can pin 60FPS outside of cities with maxed settings... inside the cities gets a little messier.  You have to lower shadow distance to medium, and god rays to medium too.
GTAV will run fine.
https://linustechtips.com/topic/487128-pc-help/#findComment-6537963
GTAV will run fine.
Can I just ask what you mean by this? I don't quite understand how it can get messier inside cities
Also, is this design loud? Because I'm planning on doing yet on it
https://linustechtips.com/topic/487128-pc-help/#findComment-6537977
And can I also ask if there's a better option from this, you said it's in the better part of the high spectrum so I'm pretty happy with that
Well you have to spend more.  The 980Ti is like $1000 in Australia.
https://www.ple.com.au/ViewItem.aspx?InventoryItemId=619955
https://linustechtips.com/topic/487128-pc-help/#findComment-6537996
ah.. May I ask for a components list that ships to Australia, is quiet and can withstand high gaming?
(I'm all good if this is asking a bit too much, you've already done enough)
https://linustechtips.com/topic/487128-pc-help/#findComment-6538009
Total: $2903.00
Total: $2001.00
https://linustechtips.com/topic/487128-pc-help/#findComment-6538052
My original build is exactly that. I made a balls to the wall build here, it is ready for a second GTX 980Ti if you just love spending money: PCPartPicker part list / Price breakdown by merchantCPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($517.00 @ CPL Online)CPU Cooler: CRYORIG R1 Ultimate 76.0 CFM CPU Cooler  ($99.00 @ PCCaseGear)Motherboard: Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard  ($239.00 @ CPL Online)Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($189.00 @ Umart)Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($243.00 @ Centre Com)Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($1069.00 @ CPL Online)Case: Phanteks Enthoo Pro ATX Full Tower Case  ($139.00 @ PCCaseGear)Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($279.00 @ CPL Online)Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($129.00 @ CPL Online)Total: $2903.00Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-11-18 17:56 AEDT+1100  I cut $40 off of the first build, it is $2001: PCPartPicker part list / Price breakdown by merchantCPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($517.00 @ CPL Online)CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler  ($45.00 @ PCCaseGear)Motherboard: Gigabyte GA-Z170-HD3 ATX LGA1151 Motherboard  ($185.00 @ IJK)Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($155.00 @ IJK)Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($134.00 @ Centre Com)Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($69.00 @ Centre Com)Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($509.00 @ Umart)Case: Phanteks Enthoo Pro ATX Full Tower Case  ($139.00 @ PCCaseGear)Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($119.00 @ Umart)Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($129.00 @ CPL Online)Total: $2001.00Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-11-18 18:00 AEDT+1100
Ok, thank you very much! I might stick with the first one and perhaps change the case (I like the weird alien case) thank you very much.
One last thing tho (cringe) can I grab a video, I looked at the five yr old one provided (xD) but it wasn't very informative, thanks!
https://linustechtips.com/topic/487128-pc-help/#findComment-6538067
and just checked this, which pcs better? The original or the edited original (the second one provided in this quoted post)
https://linustechtips.com/topic/487128-pc-help/#findComment-6538102
I seriously recommend the Phanteks Enthoo Pro.  It comes with large fans(quiet) and is very well built.  I consider it the best value at it's price range.
This is a good case, but you are spending $50 solely for aesthetics:  http://au.pcpartpicker.com/part/nzxt-case-can450ww1
http://au.pcpartpicker.com/part/nzxt-case-can450wm1
I can link you videos all day long, but:
https://linustechtips.com/topic/487128-pc-help/#findComment-6538104
All I did was change the storage solution:
The original has a 500GB SSD.
The second one has a 250GB SSD and a 1TB mechanical drive.
I personally like the 500GB SSD option.
https://linustechtips.com/topic/487128-pc-help/#findComment-6538110
