Silent case setup help needed
I know next to nothing on what fans to get or the math that goes into it from what i understand bigger fans are quieter and smaller fans pull in more are due to higher surface area I overclock a lot and i need a better neutral air system and the quieter the better. I currently have stock fans on a bitfenix colossus case http://www.bitfenix.com/global/en/products/chassis/colossus-venom/ <-- and i want a better cooling experience any help would be nice and appreciated  :)
https://linustechtips.com/topic/487126-silent-case-setup-help-needed/
Are you not satisfied with your current cooling? How are your temps?
Which components are too loud?
I know my rear exhaust is loud and my cpu cooler is next to quiet and i have my gpu fans set to not spin untill thermals are above 50c but my rear 120 for sure is really loud over all im looking for more of silence than temps since i already have decent temps my cpu never gets above 65 even in most stressing situations i put it under
Have you tried lowering the rear fan's rpm?
