Hard Drive protection problems
Go to solution Solved by TubsAlwaysWins,
The 850.
I am just going to do it on another much older desktop I own. I did try that earlier and it didn't seem to work. Thanks for the help though. I'll let you know if I have any more issus
I am doing some hard drive swapping stuff for the buisness my dad works for. I have all of the drives i am using in my computer, but for some reason windows isnt detecting one of them. (Its an Samsung 850 evo 250GB). The drive is detected in my BIOS, but not in windows. please help. Thanks
Breaking things 1 day at a time
https://linustechtips.com/topic/486963-hard-drive-protection-problems/
You need to assign a partition to it. I can't remember how though... Somewhere with the name Disk Management I think. If you've already done that I don't know :/
USEFUL LINKS:
PSU Tier List F@H stats
If it shows up in device manager:
go to computer management. Don't remember where exactly but if you search for in when you press windows it will come up.
Go to Disk Management.
Your drive will be there, assign it a drive letter (right click then go to Change Drive Letter and Path)
You may have to format it (right click > Format, use default settings)
If it doesn't show up in device manager:
I don't know for sure. May be a malfunction
-Kojin, @tomshardwareforum
99 Kid. Yes. A 'Youngster'.
World famous Couchpotatoe.
What is its format? Is it in RAID or AHCI? Is there a proper partition?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
I have my boot ssd(not in raid)
2x Hitachi 250GB drives in raid 0
the old mechanical drive with data on it
the new ssd (850 evo) that will have a copy of that mechanical dirve
Make a partition on it.
Doesnt even show up in disk managment. Do i need to leave RAID mode and enter AHCI?
Try it.
My PC wont even boot into AHCI mode. It says it had an Inacessable Boot Device
Use RAID
Disconnect the SSD
Boot
Reconnect SSD
Wait
Does it show up?
my boot ssd or the 850 ssd
The 850.
The 850.
