I am far from an expert and barely a novice, but please stick through my lack of knowledge  :P.
I'm not sure of this is possible in visual basic, but essentially i need to turn this:
If Value = 1 Then   picPostion1.Image = picPlayer.ImageElse If Value = 2 Then picPostion2.Image = picPlayer.ImageElse If Value = 3 Then  picPostion3.Image = picPlayer.ImageEnd If
Into something like this:
 x = ValuepicPostion(x).Image = picPlayer.Image
If this is possible!, Then
plz teach me master!
else
Alternative help is welcome
End If
:D
https://linustechtips.com/topic/486705-visual-basic-help/
If Value = 1 Then
....( This repeats alot in my program, hence why i wish to shorten it)
End If
x = Value
else
End If
:D
Uhm I guess what you are looking for is an Array or a List<T> .
Think of it like a box. Rather than storing each value in a named variable on it's own you could store every picposition in a series of values wich are accessible via an indexer.
That way you can access it via an Index in square Brackets.
Example with using List<T> (spoken: List Of T(ype)):
Dim myPicPositions As New List(Of myPicPositionType)()myPicPositions.Add(picPosition1)myPicPositions.Add(picPosition2)' etc... 'Dim myVar as IntegermyVar = 42picPlayer.Image = picPosition(myVar - 1).Image
I am pretty certain that indexing in VB starts with 0 instead of 1 aswell, that's why ther's the -1 part.
If I am wrong about that one, just use your myVar directly.
https://linustechtips.com/topic/486705-visual-basic-help/#findComment-6535411
Sadly I don't think what you want to do is possible, the closest you can get to this is a switch case.
Select Case Value    Case 1        picPostion1.Image = picPlayer.Image        Exit Select    Case 2        picPostion2.Image = picPlayer.Image        Exit Select    Case 3        picPostion3.Image = picPlayer.Image        Exit SelectEnd Select
It's a tad bit better than a if else tree but sadly I don't think you can do what you want :( Sorry if I am wrong
life();
https://linustechtips.com/topic/486705-visual-basic-help/#findComment-6539239
