OK, so finally I have decided to get rid of my laptop and build a PC. Gonna build for the first time, so excited.
I mostly will use my PC for 50% gaming and 50% software development (compiling android ROMs). I mostly play games like assassin's creed, farcry, call of duty, fallout 4, cs etc. but not competitively. I have two choices:
Build 1:
CPU: Intel i7-5820k
GPU: Gigabyte G1 gaming gtx 970
CPU cooler: NZXT kraken x61
Motherboard: ASRock x99 extreme6
RAM: G.Skill Ripjaws 4 16gb 2133mhz cl15 DDR4
Build 2:
CPU: Intel Xeon e3-1231 v3
GPU: Gigabyte G1 gaming gtx 980ti
CPU cooler: Stock xeon cooler
Motherboard: Asus H97 Pro-gamer
RAM: G.Skill Trident X 16gb 1600mhz cl7 DDR3
Rest of the components are same for both:
Corsair obsidian 450D mid tower case
Seasonic X-850 850w PSU
Samsung 850 EVO 250gb SSD
Western Digital Caviar Blue 1tb
Benq 1440p monitor
Now as you can notice, one build has a powerful GPU while the other has a powerful CPU. I plan on using this build for at least 4 years. I'm really torn between these two builds and I can't find which one to choose, so maybe an expert could help me out on this.
Thanks
BTW, my first post in this forum :)
CPU i5 6600k @ 4.6GHz GPU MSI R9 390 GAMING 8G RAM 8 x 2gb DDR4-2800MHz Avexir RAM Mother Board ASUS Z170 Pro Gaming Case NZXT H440 PSU Cooler Master v750 750W Storage WD 1TB Blue + Samsung 950 pro 128gb m.2 pci-e SSD Cooler Corsair H110i GTX
Monitor BenQ BL2420PT 24" 1440p 60Hz
https://linustechtips.com/topic/486702-need-some-thoughts/
Welcome to the forums :D Please remember to follow your own threads c:
As for the builds, I'd go with build 1 with the GPU changed to an R9 390 as it has much more VRAM than the 970 (8 compared to 3.5) which is helpful at higher resolutions and if you don't plan to SLI/Crossfire in the future a 600W PSU would be fine.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/486702-need-some-thoughts/#findComment-6531783
I don't know. Never used an amd video card before, also many people are saying that, AMD doesn't update their drivers frequently!? As for the PSU, I know it's a bit overkill, gonna check the x-650, but I will oc the 5820k, if I choose the first build.
https://linustechtips.com/topic/486702-need-some-thoughts/#findComment-6531815
I don't know. Never used an amd video card before, also many people are saying that, amd doesn't update their drivers frequently!? As for the PSU, I know it's a bit overkill, gonna check the x-650.
AMD released a new driver either today or yesterday which should've optomised them for Fallout 4, BO3 and Star Wars Battlefront. As I said in the post, the R9 390 outperforms the GTX 970 at higher resolutions.
USEFUL LINKS:
https://linustechtips.com/topic/486702-need-some-thoughts/#findComment-6531835
Surprisingly, the r9 390 costs more than a gtx 970 in my country :(
https://linustechtips.com/topic/486702-need-some-thoughts/#findComment-6531858
Which country? Because the 3.5GB of VRAM on the 970 will be a rather large issue at 1440p..
India. It's 5k inr more(about 75$ more). If it's worth it I have no harm to spend that much money.
Also, anyone, thoughts about the second build?
https://linustechtips.com/topic/486702-need-some-thoughts/#findComment-6531926
Bump
https://linustechtips.com/topic/486702-need-some-thoughts/#findComment-6536994
