Hey.
So I have a custom built gaming computer.... everything about it is amazing except for the internet.  When the computer was first built, I don't even know what type of Wilan card was in it, but it was a miracle if it could connect to anyones internet (friends, mine, etc).  So I recently bought an ASUS card.. the NCE-somethingsomething. It worked in the beginning, and I have been overhauling my computer and now the card doesn't work again with my internet.  It works ok at friends houses but at my house it can never connect. It is so frustrating that I am just done with WiLan cards.
So I was thinking of getting the Netgear N600 or the Netgear N900 and just bypass the whole Windows internet connection because that blows. (the Netgears connect through my computers' ethernet cable and act as a sort of router).
Unless someone has a GREAT wilan card that would go into a PCI-E slot or a PCI 2.0 slot.
Thanks.... I'm so frustrated.
https://linustechtips.com/topic/48642-wi-lan-card-replacement/
I just bought a rosewill and it works great. Give me a second and I'll fetch you a link.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166076&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-
i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
https://linustechtips.com/topic/48642-wi-lan-card-replacement/#findComment-646672
Just bought an ASUS PCE-AC66 and it is AWESOME.  The range and power are incredible.  Before I could only see about 4 networks around me and now I can see over thirty.  It supports 802.11ac and comes with an external base antenna that helps you fine tune antenna placement.  A little costy but I'd recommend this to anyone serious about going wireless.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833320136
EDIT:  I hope this wasn't the card that you were mentioning lol.
i5-3570K @4.2ghz | Gigabyte Z77-DS3H | 16GB G. Skill Ripjaw 1600mhz 9-9-9-24 (2x8GB) | 120GB Vertex 3/640GB WD 7200RPM | AMD HD7950 @ 1025mhz | 600W Corsair CS600 | Hyper 212 CPU Cooler | 5x 120mm fans 79cfm | Ultra Defender Case
https://linustechtips.com/topic/48642-wi-lan-card-replacement/#findComment-646691
Yes that reminds me that my previous card was a Rosewill... After having that card, I will probably never go back to Rosewill :)
https://linustechtips.com/topic/48642-wi-lan-card-replacement/#findComment-646901
the problem isn t you wireless card, it s most likely your router since the comp work fine at your friend house.
what i suggest? a ethernet cable, nothing beats that.
if you can t do wired, i d try a powerline kit.
or just swap your router for a better one. (asus ac66 to get wireless ac)
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/48642-wi-lan-card-replacement/#findComment-647377
Why? If you get a wireless card make sure it has dual band, I know I needed it.
https://linustechtips.com/topic/48642-wi-lan-card-replacement/#findComment-648285
No the card I was mentioning was the ASUS NCE-15
https://linustechtips.com/topic/48642-wi-lan-card-replacement/#findComment-650275
would a Intel Ultimate N6300 paired with one of these be the best solution for wireless network?
http://www.ebay.ca/itm/Mini-PCI-E-to-PCI-E-Wireless-Card-w-3-Antennas-Network-Internet-Computer-/400511612874?pt=US_Internal_Network_Cards&hash=item5d405a37ca&_uhb=1
here is a link to the N6300 at ncix:
http://www.ncix.com/products/?sku=56115
Main Rig:
I7 3820 @ 4.3GHZ---Corsair H100i---EVGA X79 FTW---DDR3 2133 16GB--- Asus GTX 780 DCII--CM Storm Trooper---corsair AX860---OCZ vertex 4 256GB--WD BE 1TB
https://linustechtips.com/topic/48642-wi-lan-card-replacement/#findComment-657299
