Hello. I had a passkey and then things went south on my computer, so i lost it. Is there any way for me to recover my old one and how? thanks
Should have been sent to your email.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/486403-passkey-help/#findComment-6527745
I think i erased that email a few weeks ago
Did you "delete" it, where you can recover it from the trash, or did you empty out your trash?  If that's the case, don't worry, per the main folding site FAQ:
What do I do if I forgot or lost my passkey?
Go to the passkey web page and fill in the same information as before. You will get another email with your same passkey.
Note:If your original email address is no longer accesible, you will need to enter a new email address, and you will be sent a new and different passkey.
Folding For Linus since July 2015
https://linustechtips.com/topic/486403-passkey-help/#findComment-6528447
