Hi,
I need a really cheap motherboard extension and found this, I just wondered is it safe without a wrapping on?
http://www.amazon.co.uk/gp/product/B00JRQA70Q?colid=VPKMEUPGGTG&coliid=I3AUX6CGG80BBL&ref_=wl_it_dp_o_pC_nS_ttl
CPU: Intel i7-4790k | Cooler: Corsair H110i GT | Motherboard: MSI Z97I AC  | Graphics Card: SAPPHIRE R9 280  | http://uk.pcpartpicker.com/p/pszsdC
http://adamredfern.co.uk
http://rewinded.co.uk
http://yewtreeservices.co.uk/
http://asiat.co.uk/
http://ssstelecom.co.uk
http://hndrx.co.uk/
http://wisemove4u.com/
https://linustechtips.com/topic/486125-atx-cable/
The copper is sealed that's all you have worry about with wires. but go with Pugs501 and get one of better quality.
My PC: i5 4690k===MSI GAMING 3===980TI===8GB-Corsair-Vangence-Pro-Series===H100i-GTX===EVGA G2 750W===Samsung 850evo m.2 boot drive===Samsung 250gb evo SSD===Seagate-Barracuda-1TB-HDD===NZXT-H440
https://linustechtips.com/topic/486125-atx-cable/#findComment-6522724
just get the Bitfenix
Okay thanks! :D It's make the cable reach with proper cable management in an ITX build so do you think this would work as this cable is probably more flexible?
http://asiat.co.uk/
http://hndrx.co.uk/
https://linustechtips.com/topic/486125-atx-cable/#findComment-6522781
Yeah, i think so
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/486125-atx-cable/#findComment-6522805
