I'm going to be completely upgrading my PC and need help
Here are the parts I'm gonna be using, I need help, tell me if they're compatable or not.
Case- enthoo pro windowed
PSU- 650w Evga bronze (or 500)
GPU- EVGA GTX 960
CPU- i5-4460
MOBO- Msi z97
RAM-8gb ddr3 2133mhz
Will be air cooling for sure at the start, don't wanna turn my PC into an ocean
https://linustechtips.com/topic/485800-compatability-help/
It's fine, you could get a cheaper motherboard, you don't need z97 with a locked CPU
and you should probably get a 380 over a 960, it's a bit faster at the same price
https://pcpartpicker.com/part/msi-video-card-r93804gd5toc
https://linustechtips.com/topic/485800-compatability-help/#findComment-6513444
GPU- EVGA GTX 960
CPU- i5-4460
MOBO- Msi z97
You don't need 2133Mhz. 1866 would be fine and get some more quality PSU
https://linustechtips.com/topic/485800-compatability-help/#findComment-6514873
