Fallout 4: Lagging, need advice.
Solved by Ostwind,
I don't even know what to clock it to to make it run better. Don't know what's safe and also i figured out it wasn't my FB usage with the problem. it was actually my gpu usage. Now what...
what do you mean its your GPU usage? The only way that can be a problem is if the GPU usage is low which means there's something causing the GPU to run incorrectly or there's a bottleneck. Since you have a 4690k a bottleneck is not likely.
