Hey guys! Im trying to help a friend with a new build. He had a budget of 900 max but wants to stay around 800. He needs a network adapter, a monitor, and keyboard and mouse. The rest he said was up to me. He wants to play games like Farcry 4, Payday 2, and Battlefield 4. I was thinking i5 4460 and gtx 970 if we can fit it in. What do you guys think?
https://linustechtips.com/topic/485679-build-for-a-friend/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($172.89 @ OutletPC)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($67.89 @ OutletPC)
Memory: Patriot Signature 8GB (2 x 4GB) DDR3-1600 Memory  ($32.99 @ NCIX US)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($304.99 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($43.99 @ NCIX US)
Power Supply: SeaSonic S12G 650W 80+ Gold Certified ATX Power Supply  ($89.99 @ Amazon)
Monitor: Acer G236HLBbd 60Hz 23.0" Monitor  ($99.99 @ Amazon)
Total: $887.61
Generated by PCPartPicker 2015-11-15 20:56 EST-0500
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/485679-build-for-a-friend/#findComment-6511680
hard.. but try to get a 960 380for a better monitor, keyboard and mouse
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/485679-build-for-a-friend/#findComment-6511695
Total: $887.61
how do you get it to be in that style? as in when you copy n paste?
https://linustechtips.com/topic/485679-build-for-a-friend/#findComment-6511709
Yeah I know thats why i came here for help xD. He gave me a 1000 dollar budget and i was like DUDE with that i can blow ur Xbox 1 out of the water. Then he started drop the budget and add things he needed.
https://linustechtips.com/topic/485679-build-for-a-friend/#findComment-6511732
There's a [bB] code button next to the permalink.
https://linustechtips.com/topic/485679-build-for-a-friend/#findComment-6511735
Go with my build.  It's relatively small and should max out most games at 1080p.
https://linustechtips.com/topic/485679-build-for-a-friend/#findComment-6511739
