I have a drain system where the bottom 2 radiators (one in the back) are the drain port, they got an extra port I use for it.
The problem is that my reservoirs has a pass through tube, that makes is so that only the top chamber is connected to the "drain radiator".
So I'm left with a lot of liquid in the system.
Is there a way to get that liquid out or do I need to get another another set of drain ports?
Was thinking about setting it at the bottom of the reservoirs.
Picture from when I was test filling earlier.
Bigger image: http://s14.postimg.org/eu3jgfqvj/P1010591.jpg
I speak my mind, sorry if thats a problem.
https://linustechtips.com/topic/485617-draining-the-system/
-SNIP-
Oh that's some funky tubing runs you have there, it would explain the problem with bleeding you had earlier, but in general having the drain ports at the bottom of the res and radiators will drain the largest amount of fluid from the loop.
https://linustechtips.com/topic/485617-draining-the-system/#findComment-6510804
is that a 900D?
nvm
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/485617-draining-the-system/#findComment-6510811
Would running the pumps temporarily to push the liquid out the drain port work?
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/485617-draining-the-system/#findComment-6510834
