So my fire alarm upstairs went off witch set the downstairs one off but not the one in my kitchen witch was Strange, I pushed the hush button on the two that were going off and they shut up But now the one outside my room won't shut up and Keeps doing a single beep every Min or so what does this mean
My speakers dont even fit on or under my desk...PA's FTW
https://linustechtips.com/topic/485571-help/
Have you tried changing the battery?
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/485571-help/#findComment-6510226
Doesn't that mean the battery is low and it's warning you now while it still can so you'll change it before it needs to be able to go off and can't?
https://linustechtips.com/topic/485571-help/#findComment-6510228
Contact someone to fix it or you fix it, if your house burns down and that is faulty, insurance don't have to pay for the house because you didn't take care of it.
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/485571-help/#findComment-6510247
What the fire alarm is trying to say is;
"Dude change my batteries or if there is a fire you're going to die horribly but I will be fine because I am a fire alarm. Also if the house does burn down no one has to pay for it and you will be put in a bad situation. Just saying :)"
Gaming/Editing Rig: CPU - i7 4790K|GPU - GTX 970 SSC|RAM - 16GB HyperX Fury|MOBO - Z97S SLI KRAIT|HDD - 1TB Western Digital|SSD - Samsung 850 EVO 500GB|PSU - SuperNOVA G2 650W
Check out my YouTube channel and maybe subscribe if you get the time? https://www.youtube.com/channel/UCTkGuHFjcWH73lT8RqLK9TA
Check out my digital store for cool products! https://sellfy.com/Zolias
https://linustechtips.com/topic/485571-help/#findComment-6510248
no I just thought they were connected to the mains
Oh sorry I was thinking of a smoke alarm
https://linustechtips.com/topic/485571-help/#findComment-6510827
