Opinions on this build? This isn't for me it's for a friend who is a real conformist. He thinks this is overkill but I told him to fuck off. Anyways is it good?
PCPartPicker part list: http://pcpartpicker.com/p/bYZ9gs
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($241.98 @ Newegg)
Motherboard: ASRock Z97 Extreme3 ATX LGA1150 Motherboard  (Purchased For $0.00)
Memory: Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1600 Memory  ($41.99 @ Amazon)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (Purchased For $0.00)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  ($358.85 @ Amazon)
Case: NZXT S340 (Black/Blue) ATX Mid Tower Case  (Purchased For $0.00)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  (Purchased For $0.00)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  (Purchased For $0.00)
Total: $642.82
Generated by PCPartPicker 2015-11-15 16:23 EST-0500
https://linustechtips.com/topic/485522-pc-build-thoughts/
I wouldn't say its overkill. It's a perfect build for the future. CPU is strong enough for games for the next 3+ years and the GPU can be upgraded whenever but its a 970 so thats pretty good for at least 2 years on 1080p as well.
Case: Fractal Design R4 (x2 Noctua 140mm Fans, x2 Fractal Design Fans)            Processor: Intel Core i7 3770k @4.2GHz (Hyper 212 Evo)             Audioengine A5+ Black Speakers
Motherboard: MSI Z77A-G45 ATX LGA1155 Z77 DDR3                                           Graphics Card: EVGA GTX 1080 SC                                               Corsair K65 RGB Cherry MX Red
Memory: G.SKILL Ripjaws X 4X4GB DDR3-1600                                                     Power Supply: OCZ Z-Series Semi Modular Gold 850W                 ASUS & LG 21.5 Monitor (Dual monitor arm)
https://linustechtips.com/topic/485522-pc-build-thoughts/#findComment-6509668
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($304.99 @ Newegg)
Power Supply: SeaSonic 650W 80+ Gold Certified ATX Power Supply  ($83.98 @ Newegg)
Total: $672.94
Generated by PCPartPicker 2015-11-15 16:28 EST-0500
Moist
https://linustechtips.com/topic/485522-pc-build-thoughts/#findComment-6509669
Added a cooler and changed the GPU.
Video Card: MSI Radeon R9 390 8GB Video Card  ($329.99 @ Newegg)
Total: $642.55
https://linustechtips.com/topic/485522-pc-build-thoughts/#findComment-6509670
Total: $588.96
Generated by PCPartPicker 2015-11-15 16:29 EST-0500
I guess it's too late to change taht PSU?
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/485522-pc-build-thoughts/#findComment-6509678
Total: $672.94
Total: $642.55
Is the 390 better than a 970? Personally I prefer the 970 since it's from Nvidia and they simply offer more things. Like G sync which I have become accustomed to.
https://linustechtips.com/topic/485522-pc-build-thoughts/#findComment-6509697
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Total: $723.45
Generated by PCPartPicker 2015-11-15 16:33 EST-0500
Added a cooler that wont be an eyesore in the S340, added a better GPU and added a PSU that it way,way, waaaaaaay better than a CX600
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/485522-pc-build-thoughts/#findComment-6509717
Total: $723.45
Okay so power supply and Graphics card will be changed. Thanks
https://linustechtips.com/topic/485522-pc-build-thoughts/#findComment-6509749
The CX would have been fine with the 970, but the 390+any OC'ing with the CPU/GPU would be stretching it thin.
https://linustechtips.com/topic/485522-pc-build-thoughts/#findComment-6509775
Total: $642.82
First of all add a cpu fan in order to overclock the cpu, otherwise the build is really good, for 1080p or 1440p gaming its really good! For 4k tho its not! Also I would recommend you not to buy that PSU... I know its cheap, but its safer to get a more expensive one, because the power supply is the one thing that can fuckk up the whole PC! I would recommend a Supernova ;)
https://linustechtips.com/topic/485522-pc-build-thoughts/#findComment-6511223
