I recently purchased a Samsung 850 EVO and installed it on my Asus Z97-AR mobo.  The problems is the SSD software says it is connected to a 3gb / s port on my mobo, except I do not even have a 3gb / s port on my mobo, the Z97-AR only has 6gb / s ports and express ports.  I know this is not a software glitch because I did a SSD speed test with multiple software, all of them said the speed was around 240mb / s.  How do I fix the issue?
https://linustechtips.com/topic/485512-major-ssd-issue/
240 mb/s is nowhere near 3 gb/s or 6 gb/s; you should be fine
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/485512-major-ssd-issue/#findComment-6509636
try a different cable and port. Look at your bios if ahci is enabled. Did you install the OS directly onto the SSD or clone it from a HDD? Maybe your mobo drivers are not all installed? Try checking your device manager if there are any yellow warning signs.
CPU: Intel i7 5820K CPU @ 4,3 GHz CPU Cooler: Noctua NH-D15 Mobo: ASUS X99-A/USB-3.1 Ram: Kingston HyperX Fury DIMM Kit 16GB, DDR4-2400 Optical: LG GH24NS DVD Burner Optical: BD Reader SSD: Samsung SSD 850 Pro 256 GB SATA 6GB's PSU: Seasonic X650 Video Card: ASUS STRIX GTX 970 Case: fractal design Define R5 black OS: Windows 10 64bit Monitor: Dell U2715H
https://linustechtips.com/topic/485512-major-ssd-issue/#findComment-6520329
I remember hearing something a few months back about Samsung issuing a firmware update for their EVO drives. You might want to dig into that a bit. Your SSD may need that firmware update.
CompTIA A+ Certified
"We are all cups, quietly and constantly being filled. The trick is knowing how to tip yourself and let the good things pour out." - Ray Bradbury
https://linustechtips.com/topic/485512-major-ssd-issue/#findComment-6524226
