Well, i have posted quite a lot about builds and the lot, but i finally managed to do something which has discombobulated me. I accidentally pulled my power cable out, subsequently cutting the electric in my house. When my electric came back on, my computer wouldn't boot so i opened the case, nothing smelt funky so i was confused. I decided to use a old lead, and that wouldn't boot either. I came to the conclusion it was blown, but it has none of the typical signs, except for a few abnormalities on the pins on the power supply. It was EVGA 500w white which i have had no problem with at all. If anyone has any idea what happened or if its fixable please let me know.
P.S i checked the internals and no capacitors looked dodgy.
https://linustechtips.com/topic/485449-power-supply-broke/
You opened a PSU?... brave and silly person.
If you have tried a new lead to rule out the possibility of the fuse in the plug breaking, and you are sure your system gets no power at all then It would suggest that your PSU is broken yes.
edit: Have you tried using another wall socket?
Quack 🦆
https://linustechtips.com/topic/485449-power-supply-broke/#findComment-6508872
yep im with Altecice here.. you are a brave guy for opening up a psu... could do some serious damage to yourself there. did your computer turn on at all? or did it just fail POST?
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/485449-power-supply-broke/#findComment-6508900
Try the paper clip test and see if it turns on. You take a paper clip and stick one end into pin 15 and the other into 16 (or the Green and Black wire). If that doesn't work, then it is probably dead.
CPU: Intel Core i7 4790K @ 4.6 GHz
Motherboard: Asus ROG Maximus VII Hero
RAM: Corsair Vengeance 32 GB @ 1903 MHz
GPU: Nvidia GeForce GTX Titan X @ 1100 / 7030 MHz
Case: Corsair Obsidian 750D with the Ghetto LED 5000 lighting kit
Storage: 1TB Samsung 840 EVO
PSU: Corsair AX1200i
Display: Dell P2415Q
Cooling: Corsair H100i
Keyboard: Corsair Vengeance K95 RGB (Cherry MX Reds)
Mouse: Sharkk MMO Pro
OS: Windows 10 Pro
Intel Core 2 Quad Q9550
Gigabyte GA-G41MT-S2PT
Arctic Freezer 7 Pro Rev 2
G.Skill Value 8 GB (1333 MHz)
Cooler Master N200
Seagate Barracuda 1 TB
Insignia 300W
Windows 7 Enterprise
Intel Core i3 3240
Asus P8Z77-V LX
4790K stock cooler with Cooler Master HTK-002 thermal paste
Corsair XMS3 4 GB (1333 MHz)
Cooler Master HAF 912
Thermaltake TR2 430W
Windows 10 Pro
https://linustechtips.com/topic/485449-power-supply-broke/#findComment-6508909
yeah dude, i have but i just cant figure out why it happened. lso is it meant to kill itself in that situation?
https://linustechtips.com/topic/485449-power-supply-broke/#findComment-6508910
Dont worry, i have done this loads of times, i just avoid exposed wires
https://linustechtips.com/topic/485449-power-supply-broke/#findComment-6508926
PSU's have internal fuses that break to stop damage to your Hardware (sort of self sacrifice, Over Volt Protection). Its possible that one of them have broke but they aren't replaceable and you will want to be buying a new PSU.
Quack 🦆
https://linustechtips.com/topic/485449-power-supply-broke/#findComment-6508929
can you give some more detailed instructions to that im not sure what you mean
https://linustechtips.com/topic/485449-power-supply-broke/#findComment-6508937
ok thats that off my mind, i thought is was unusual but, £30 for £470'worth of gear is definately worth it
https://linustechtips.com/topic/485449-power-supply-broke/#findComment-6508953
If you are buying a new PSU and it still wont turn on then you can return it anyway :)... then again you are going to have larger issues to deal with if that is the case.
Quack 🦆
https://linustechtips.com/topic/485449-power-supply-broke/#findComment-6508968
Usually no unless there was a surge when you lost (or regained) power. If you want to open it up again, you can look for a burnt fuse. Probably isn't that but might as well check. If it's burned, you will have to RMA it.
Take a look at this guide since it explains it better than me lol http://www.wikihow.com/Check-a-Power-Supply
OS: Windows 10 Pro
Cooler Master N200
Insignia 300W
Intel Core i3 3240
Asus P8Z77-V LX
Windows 10 Pro
https://linustechtips.com/topic/485449-power-supply-broke/#findComment-6508970
Do you mean you opened your PC case, not the actual PSU itself?
He did both.
OS: Windows 10 Pro
Cooler Master N200
Insignia 300W
Intel Core i3 3240
Asus P8Z77-V LX
Windows 10 Pro
https://linustechtips.com/topic/485449-power-supply-broke/#findComment-6508989
btw rma is not an option as postage would cost more than the product itself
https://linustechtips.com/topic/485449-power-supply-broke/#findComment-6508995
GG. You can try to return it to the store if it's new. Otherwise you'll either need a new PSU or learn how to solder well enough to replace high voltage electronics :P
OS: Windows 10 Pro
Cooler Master N200
Insignia 300W
Intel Core i3 3240
Asus P8Z77-V LX
Windows 10 Pro
https://linustechtips.com/topic/485449-power-supply-broke/#findComment-6509013
