Use http://pcpartpicker.com/.  What's your budget?
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/485365-first-pc-build/#findComment-6507911
http://pcpartpicker.com/ is a useful website for making parts lists. The PSU you chose is of very low quality, a tier 1 or 2 PSU from http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ be great for this build. Also, a 390 would be better for the price compared to a 970 unless you really need CUDA. Oh, and, welcome to the forums :D Please remember to follow your own threads.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/485365-first-pc-build/#findComment-6507925
If I could recommend one thing and 1 thing only :P it would be the CPU if u don't care about rendering video's and only care about CAD and gaming preformance u should go with the i5 4690k it would save u a couple of bucks and u could put that into buying a 980 maybe instead of the 970 which inturn will give u more preformance in games and in CAD
CPU: R7 5800x -- Mobo: Gigabyte B550 Gaming X v2 -- RAM: 2x16GB Kingston Fury Renegade -- GPU: Asrock RX 6800 XT Phantom Gaming OC -- Case: Fractal Design North Walnut/Black Mesh -- Storage: 2TB 970 Evo Plus, 4TB NM790 -- PSU: BeQuiet Pure Power 11 Platinum 650w -- Displays: AOC AGON  AG352UCG, Dell Ultrasharp U2715H -- Cooling: Noctua NH-D14 -- Mouse: Corsair M65 -- Keyboard: Func KB 460 MX Blue -- Sound: Motu M2 -> THX 789 -> DT880 600Ω -- Mic: RØDE NT1-A
RIG 2: Intel i5-8400, 16 GB RAM, RTX 2070S
https://linustechtips.com/topic/485365-first-pc-build/#findComment-6507938
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($324.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($123.89 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($85.89 @ OutletPC)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($299.99 @ Amazon)
Case: Corsair 200R ATX Mid Tower Case  ($49.85 @ Amazon)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($61.99 @ SuperBiiz)
Total: $1064.98
Generated by PCPartPicker 2015-11-15 13:23 EST-0500
https://linustechtips.com/topic/485365-first-pc-build/#findComment-6507961
PCPartPicker part list: http://pcpartpicker.com/p/LjwDYJ
Price breakdown by merchant: http://pcpartpicker.com/p/LjwDYJ/by_merchant/
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($138.98 @ Newegg)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2400 Memory  ($87.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($51.88 @ OutletPC)
Video Card: MSI GeForce GTX 960 4GB Video Card  ($212.99 @ Newegg)
Case: Corsair SPEC-02 ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($53.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($99.98 @ OutletPC)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($29.89 @ OutletPC)
Total: $1085.17
Generated by PCPartPicker 2015-11-15 14:04 EST-0500
https://linustechtips.com/topic/485365-first-pc-build/#findComment-6508301
Well u could opt to go with a somewhat larger cooler if u want to overclock if not u should just stay with the other cheaper one it won't really matter if the cpu runs a couple of degrees hotter under non overclocking gaming load if that would even be the case
https://linustechtips.com/topic/485365-first-pc-build/#findComment-6519130
