HELP! CPU FOR SALVAGE
Go to solution Solved by ApolloX75,
Guys question someone just gave me their old PC for Free and Here what i can salvage
CPU - Intel Core 2 Quad Q8200
MOBO - Acer EG43M
I have this in my Previous CPU
RAM - Samsung PC3-10700 2GB
GPU - NVIDEA GeForce 6200 TurboCache
i was planning in upgrading RAM GPU and HDD to SSD.
But can someone explain to me this?
Memory 1GB / 2GB DDR3 1333/1066/800 Un-buffered Non-ECC DIMM support
Support single channel 64 bit mode with maximum memory size up to 8GB
Support un-buffered DIMM (Intel ICH10R)
DIMM Slot: 4
Memory Max: 1GB to 8GB DDR2 memory technologies
This was in the Acer Support Manual.
and what GPU Should i Pair it with? any Suggestion?
Ehhh I wouldn't go crazy for it but it's a decent chip at least. The g43 motherboard is nothing to write home about.
Maybe pair an r7 260X or maybe an r9 270x but I wouldn't do more than a 280/380 or gtx 960 at the absolute most.
As for the motherboard manual it's just telling you that the board can handle up to a 8Gb max of DDR3 at a speed of 1333MHz. And it will do it either with 4 2Gb sticks, 2 4Gb sticks or one 8Gb stick. You can put 1833MHz DDR3 in there if you want, the bios will clock it down to 1333MHz automatically.
And the "1GB to 8GB DDR2" bit is likely a misprint.
MOBO - Acer EG43M
DIMM Slot: 4
GAMING RIG
i5 4590 / 16GB / RX 480 8GB
https://linustechtips.com/topic/484335-help-cpu-for-salvage/
MOBO - Acer EG43M
DIMM Slot: 4
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/484335-help-cpu-for-salvage/#findComment-6497223
Thanks for your help man! ill look for cheap stuff so i can use this for now. and save more for a proper setup.
GAMING RIG
https://linustechtips.com/topic/484335-help-cpu-for-salvage/#findComment-6499904
