R9 380 Fan problem?
Solved by LabRat,
you're not the only one who misses the manual fan control that's been eliminated in the new CCC overdrive section. I never had a card get this hot before the fans kicked in. and I don['t think I ever had a card get this hot because I always set the fan speed to my liking keeping the temps down, not letting the gpu heat up or heat up the system. feel abused so AMD can say they're more energy efficient. Lets hope they bring it back.
