My OS is Windows 10. My bitlocker is on, I disabled regedit, cmd, access to control panel and removable access storage. My account is the only Administrator of the computer. The other account is a local guest account. How is this guest able to make that account an administrator? I really have no idea.
https://linustechtips.com/topic/483396-the-administrator-issue/
Not going to specify, but the guest account has a loophole that some virtual desktop programs are able to switch accounts instead of desktops accidently.
TheRedDragon    |i7-5820k (4.2Ghz) || MSI X99S SLI Plus || Crucial 2x8gb 2133hmz DDR4 || MSI GeForce GTX 980Ti 6Gb || Sandisk 128Gb SSD || Seagate Barracuda 3Tb |EVGA 1000W 80+ Pltnm ||
dossium.net >
Posts that won the internet - Verticle Mice
https://linustechtips.com/topic/483396-the-administrator-issue/#findComment-6484604
you can also loop hole via command prompt.
Yes, but you don't need the admin permissions for the program's loophole. Unless the program installation is blocked, where maybe via usb a portable program could do it.
dossium.net >
https://linustechtips.com/topic/483396-the-administrator-issue/#findComment-6484618
idk if it is just my school, i neeed to test at my house
but i can boot the pc into comand propmt and create a new admin account no problem that way
https://linustechtips.com/topic/483396-the-administrator-issue/#findComment-6484622
or just use the hidden admin account xD
Or if you just need to use a computer, not a specific account, linux live USB ftw.
dossium.net >
https://linustechtips.com/topic/483396-the-administrator-issue/#findComment-6484632
Linux on a usb, edit files. To stop this, set a bios admin password. Then edit the boot option to disable cd/dvd boot and usb boot.
If death has no cost, life has no worth
The dead are gone, the living are hungry
Life is not about finding yourself, it's about creating yourself.
https://linustechtips.com/topic/483396-the-administrator-issue/#findComment-6485156
Thanks for this. However, I don't think this is the way he does it. I purposely leave my account locked with browsers open, so when I get home and my account is still logged in with the same browsers/pages open, I can verify whether or not he rebooted the system and tried starting with linux or something off a USB. I'm guessing the user might be using something like a virtual desktop software?
https://linustechtips.com/topic/483396-the-administrator-issue/#findComment-6493080
