Hello guys,
I have been using a setup with 2 low end gpus for 6 months by now and had no problems the gpus are:
Geforce 210
Geforce GT 730
The driver version I was using was: 341.81
For almost all games I play this driver version was fine and I could configure the GPUs so that they balanced the workload without SLI.(210 did Physx and the 730 GT did the other stuff)
Now I want to play Black Ops 3 and it runs for a while fine at 40 FPS or so and then randomly crashes (Windows kernel mode driver version 341.81 has stopped responding and has sucsessfully recovered) . It also gave me a warning I should update the drivers. So I updated my drivers to the latest version and the 730 GT seems to run fine with the driver but on the 210 I get a code 43 with a yellow triangle and windows saying it isn't working properly. So I rolled back the driver on the 210 but then windows rolls the driver of the GT 730 back too. any Ideas on how to update the driver without getting problems with my 210?
Here is some info about my system:
Mobo: Gigabyte g1.Sniper b5 (Latest BIOS version F9)
Processor: Intel Pentium G3220 @ 3GHz ( I Know it is bad and not suitable for gaming but it was CHEAP and yes it does run BO3)
Ram: 8Gb cosair value select one stick DDR3
Os: windows 10 64 bit
https://linustechtips.com/topic/482968-dual-gpu-driver-problems/
Hello guys,
Remove the 210 and try just play on the 730
https://linustechtips.com/topic/482968-dual-gpu-driver-problems/#findComment-6478723
