Why that one instead of the noctua fan?
Oh. It's not better than the Noctua fan. (At least I don't think so. I haven't seen any testing/benchmarks. I have one myself and it works well though.) I was just giving another option. Didn't know if you had a budget.
https://linustechtips.com/topic/482676-which-noctua-fan/#findComment-6475988
Yea according to there site is the best case fan, but being the case I have the 120mm fan is the main intake/fan so maybe I need something stonger to push more air? I have no exhaust fan so I'm going with positive air pressure.
https://linustechtips.com/topic/482676-which-noctua-fan/#findComment-6479525
