Sony Xperia Z Problem
Go to solution Solved by Bazilias,
SOLVED!
Hello LTT's!
I have a problem.
Recently i flashed Cyanogenmod 12.1 on my Sony Xperia Z. Everything worked fine until yesterday. When I turn on my Mobile Data (3G/4G) I get an exclamation mark next to it. when I'm trying to browse on the internet it doesn't let me because I have no network connection. I thought the problem was the APN because there was nothing In there. I filled in the APN-settings and restarted my phone. I thought the problem was solved but I still don't have any connection with the network. Does anyone know how to solve this problem?
Thanks in advance!
https://linustechtips.com/topic/481775-sony-xperia-z-problem/
Hello LTT's!
I have a problem.
Thanks in advance!
Op je muil gauw! Kapot gemaakt godverdomme!
Give me a boost.
https://linustechtips.com/topic/481775-sony-xperia-z-problem/#findComment-6462613
Rustig aan Nick! Nog 2 maanden stage dan kan je weer naar school :D
Alles wipen, opnieuw flashen zonder simkaart en de simkaart na de installatie plaatsen
Het probleem is opgelost! Ik was vergeten om de APN-Type op default te zetten :D
Bedankt voor je hulp!
https://linustechtips.com/topic/481775-sony-xperia-z-problem/#findComment-6462651
