Heey!
I just installed my new 780, and there´s something odd happening. When I turn on my computer, it appears the "Starting Windows", but when it finishes loading, it seems that the connection between the 780 and my monitor stops, and it show nothing. However, if I enter my BIOS before it starts loading windows, and close it, it works normally.
Any Ideas?
My rig:
asus sabertooth z77
evga gtx 780 SC
seasonic 850W power supply
https://linustechtips.com/topic/47998-gtx-780-problem-help/
Previous driver uninstalled?
CPU: Intel Core i7 4790K @ 4.4GHz (cooled by Corsair H110) Motherboard: ASUS Maximus VI Formula RAM: 16GB DDR3 1600MHz CL9 | GPU: ASUS GTX780TI-DC2OC-3GD5 Case: NZXT Phantom 630 Storage: Samsung 840 Pro 128GB + 3 x WD Black 500GB  + WD Black 1TB + WD Black 2TB + Kingston V300 120GB PSU: SeaSonic Platinum 660W Monitors: 3 x Iiyama ProLite XU2390HS-1 Keyboard: Logitech G910 Orion Spark Mouse: Logitech G502 Protheus Spectrum Mousemat: Steelseries QcK Heavy (40x45) Headset: Kingston HyperX Cloud II Speakers: Logitech Z906
https://linustechtips.com/topic/47998-gtx-780-problem-help/#findComment-637449
Check if there is any other drives could be causeing issues by going into safe mode and seeing if it loads up.
So I spelt something wrong in my post... I don't care I don't read through what I write and I type very quickly.
Intel 3770k stock, MSI Z77A-GD65, MSI GTX 760, Corsair Vengence DDR3 1600Mhz 16Gb, Corsair RM 550W, Samsung 830 256Gb, some random hdds.
https://linustechtips.com/topic/47998-gtx-780-problem-help/#findComment-637514
Put the card in the second PCI-e slot, might help.
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/47998-gtx-780-problem-help/#findComment-637529
Fresh windows install, i know it sux but might help??
Gaming Computer | Case: CM Storm Scout II | MB: Asus P8Z77-V LK | CPU: i5 2320@3,6ghz | GFX:  MSI GTX 770 Gaming | RAM: 8gb DDR3 @ 1333mhz | Storage: 1TB Seagate Barracuda | Monitor: 1x Asus VG248QE @ 144Hz , 1x Samsung SyncMaster SA300 @ 77hz OC'd
Other Device's | Phone: Samsung Galaxy S3 LTE@OmniROM | Tablet: Samsung Galaxy Tab 2 10.1@OmniROM | Laptop: Lenovo ThinkPad T61 Win 8.1
https://linustechtips.com/topic/47998-gtx-780-problem-help/#findComment-637638
What display output connection are you using?
i7 930 @ 4.2Ghz | Gigabyte X58A-UD7 | Seagate ST2000DX001 SSHD 2TB | WD5000AAKX 500GB | Samsung SH-B083A Bluray Drive | Gigabyte GTX 670 2GB GV-N670OC-2GD | Corsair 12GB 1600Mhz CMZ12GX3M3A1600C9 | Corsair H50 in Push Pull | SeaSonic X750 | CM 690 II Advanced | Windows 7 Ultimate x64 | HP 2159M 1080p | Asus ProArt PA238Q 23" 1080p IPS Monitor | Asus VS239H IPS 1080p (Portrait) | Razer BlackWidow Expert MX Blue (2011) | Razer Lachesis 5600
https://linustechtips.com/topic/47998-gtx-780-problem-help/#findComment-637663
I´m using a VGA output with the adaptor that came with it. I tried using HDMI, but it didn´pt work too
Well it sounds like Windows default display must be one of the other connectors
https://linustechtips.com/topic/47998-gtx-780-problem-help/#findComment-637925
How do I change that ?
try multiple different connections from your graphics card to the monitor. so try hdmi, display port etc etc. this actually might be the answer, considering I have a dual monitor set-up and the second monitor goes dark when on the log-in screen
Gaming/Engineering PC: -i7 6700K, 4-4.2GHz "Eleanor" -ASUS ROG HERO VIII MOBO -16GB DDR4 3000MHz Corsair (2x8GB) -Gigabyte Windforce 980Ti OC edition (1405MHz GPU clock) -H110i GT Corsair CPU Water cooler -980GB Sandisk Ultra II SSD -Corsair 450D ATX Case -RM850i Corsair PSU (Modular) -28” 4K Samsung -27” 1080p Samsung
https://linustechtips.com/topic/47998-gtx-780-problem-help/#findComment-664110
