So I just built a new pic and wet windows on my ssd. I also have a hard drive to put my games in. My boot priority is set to ssd. My hard drive is not prioritized anywhere. I know my motherboard recognizes my hard drive because I can swap between ssd and the hard drive. I don't want to swap to my hard drive because my boot priority will be on my hard drive. When I look at my computer, it only shows up with the ssd. I unplugged and replugged my hd and still not working. How do I get it to show up both ssd and HD on my boot priority bar
In case ur wandering I'm using an msi z77a-g43 with click bios 2
https://linustechtips.com/topic/479228-hard-drive-not-recognizing/
~snip~
Hey there :)
Is your drive recognized in Device Manager and Disk Management? All new drives need to be initialized first and then their unallocated space needs to be allocated, partitioned, formatted and a letter needs to be assigned. Then you should see the drive in My Computer and be able to operate with it.
If that doesn't help, do check all your cables and ports and possibly try the drive on another computer. :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
