Pressure on Sata Cable
Solved by Heroi,
Something like this may help: http://www.newegg.com/Product/Product.aspx?Item=9SIA4TZ2SP1510&cm_re=silverstone_sata-_-12-162-042-_-Product
As for the adapter, it should work if you have two EPS cables coming from your PSU. But I will never recommend adapters for such a use case. I also wouldn't recommend any Ultra branded products for anything.
I think that cable will work fine thank you. Also could you elaborate more on why I need two EPS cables?
