 So I'm preparing a USB for a Win 8.1 install. I THINK I did it right (I've not done this before, I know, heresy) and I'm wondering if there's a way to test it without actually reinstalling my OS? :D
https://linustechtips.com/topic/478777-bootable-usb-drive-question/
the easiest way would be to rightclick your windows folder and see when the last edit was
although you probably have to enter the windows folder and look at the last edit date on the folders inside
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
