Max graphics adapter 1000 mb?
Go to solution Solved by Mr.Meerkat,
That just means that the integrated GPU can only use a maximum of 1gb of system ram I'm pretty sure...
Can you link the motherboard?
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
Do you mean the integrated graphics use system ram?
yes that's why if you buy an APU you want fast DDR3
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
