Will it fit?
Solved by Arcanekitten,
will
http://www.gigabyte.com/products/product-page.aspx?pid=3448#ov
fit in
http://www.newegg.com/Product/Product.aspx?Item=N82E16811353023&ignorebbr=1
I already have the motherboard, just wondering about getting a case that is not very expensive for my buddy.
The case supports ATX and the mobo is a ATX mobo so yes ![]()
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
8
derekchan ·
Posted in New Builds and Planning13 -
1
3
7
5
7
play_circle_filled
Latest From ShortCircuit:
