Help choosing SSD
Go to solution Solved by Samppa221,
850 evo
SSD's are 2.5"
Hi guys!
I'm looking to replace the HDD in my laptop with an SDD because the slowness is driving me crazy.
Now first of all I ran DiskInfo on my laptop and saw that the connection is SATA 3.0GB (Sata 2), I just want to make sure that a SATA 6.0GB (Sata 3) ssd will work in my laptop?
And then my second question is to help me choose between 3 ssd's. The place where I get all my computer stuff has 3x 120GB SSD's all for about the same price, and I've read on a lot of forums that all of them are pretty much the best. So now I just have to choose between the 3.
They are:
1. Adata Premier Pro SP900 128GB
2. Corsair Force LS 120GB
3. Samsung 850 EVO 120GB
I like the Samsung 850 EVO the most as it has a 5 year warranty (2 more than the rest) and everyone only has good things to say about it. So what do you guys think?
P.s Do I have to get a special bracket or spacer for the ssd or is it the same size as the 2.5 HDD that I have now?
Thanks a lot in advance!
99 little bugs in the code, 99 little bugs, you take one down, you pass it around... 10335 little bugs in the code :mellow:
Intel Core i7 3770, ASUS Maximus IV Gene-Z, DDR3 @1866MHz 16GB (2x8GB), GIGABYTE GTX 1060 G1 Gaming 6GB
https://linustechtips.com/topic/477772-help-choosing-ssd/
850 evo
SSD's are 2.5"
https://linustechtips.com/topic/477772-help-choosing-ssd/#findComment-6401385
Samsung is the best one.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/477772-help-choosing-ssd/#findComment-6401397
I'll go with the Samsung then, thanks guys!
https://linustechtips.com/topic/477772-help-choosing-ssd/#findComment-6401428
