Micro atx, Mini atx.
Go to solution Solved by CoolBeans,
No! No! lol. Why you guys act all idiots?!.. I'm asking for a very small case with a good gaming parts in. I want to know what I can buy around $500 and another of $700, so I can see what I can add or change for $200. I dnt need windows, HDD/SSD keyboard mouse or screen. I just want to know a very small good case, motherboard, cpu,gpu,ram pw sup or even a good laptop for this price. That's all. Just what's the best for this amount of money.
How am I an idiot for asking a simple question. Anyways here is something http://pcpartpicker.com/p/1tZWU
Hi,
..I'm moving around alot! even in my city countrym even sometimes I change country. I'm looking for a good gaming pc. I'm interested in the smallest thing possible. Smallest motherboard, case, cpu cooler and a decent airflow. I'm interested to know two rigs between two amount of money. First I want to know what I can buy and have around $500 and second $700. Be open minded, not fanboy or so.. and if there is a good gaming laptop pls list it on. Thanks!
https://linustechtips.com/topic/47761-micro-atx-mini-atx/
Micro ATX takes a bit more space. Has more customization options
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-634066
Why not just get one 1200$ PC?
maybe hes waiting for the 9k series :O
OT:
I really like mini-itx it looks really cool. You should go with it if you can.
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-634079
I dont know if you guys understood me, but I was expecting to see some lists with a cpu,mb, ram,gpu etc etc... Can you recommand a verry small case, rly small!! and good at gaming, 1. around $500 and another at $700.. Is this possible?
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-634197
Do you need a copy of Windows?
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-634518
maybe hes waiting for the 9k series :o
OT:
mATX boards are also able to support two graphics cards.
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-634682
For one, we don't even know where you're located so we don't know what would fit your small budget the best.
Please read: http://linustechtips.com/main/topic/3061-build-plan-thread-reccomendations-please-read-before-posting/
Realize that we'd have to assume some things if we were to try suggesting parts and that would probably take longer than if you had provided us more information in the first place.
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-634694
The Prodigy M was released recently, which supports mATX at the same size as the Prodigy (an mITX case). It's very small and has a very modest price, you can't get much smaller than that without it being an inferior value.
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-634699
Actually, the Prodigy is far from 'very small'. It's an itx the size of an matx case. The Prodigy is in fact one of the larger itx cases.
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-634813
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-634889
Actually, the Prodigy is far from 'very small'. It's an itx the size of an matx case. There Prodigy is in fact one of the larger itx cases.
It's still a very small case. Sure you can go smaller, but generally it gets too expensive for this price point as I pointed out above.
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-634990
There are several mini itx cases that are cheaper a a few around the same price point: http://pcpartpicker.com/parts/case/#sort=a6&t=9,10&u=1
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-635044
The list is blank?
Edit: Compatibility filter was on. Those cases support mITX aren't only mITX cases, but instead may support much larger form factors, and even the mITX-only cases pretty much have a high price tag or probably aren't suitable to the OP's standards.
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-635056
The list is blank?
 It's a url of filtered cases. If you still have a build in your cookies, it could appear blank. Clear your parts list and it would work as intended.
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-635064
What do you mean? The largest form factor any of the cases that were listed near or below the Prodigy's pricing don't support anything larger than mini itx.
What's the point of a mitx-only case? How are all of these cases not suitable to the OP's standards?
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-635153
A lot of these cases probably won't look good to the OP, and the majority of them are quite a bit more expensive than the Prodigy. Also consider the overall layout of the case, the Prodigy has received very positive feedback in terms of design as well, and includes much more customizability such as windowed side panels and various colors, as well as the budget that the OP has (~$600 total) which really restrains case choice.
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-635172
Looks are subjective. Also, I was talking about the cases with the same or lower price of the Prodigy, which there are. The Prodigy isn't the only good itx case and isn't exactly a cheap case to begin with.
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-635194
Of course looks are subjective, I never said they weren't. I also didn't say that there weren't lower priced cases, just that there weren't really better choices, or even that the Prodigy is the only good mITX case. You seem to be attacking an argument that doesn't exist.
https://linustechtips.com/topic/47761-micro-atx-mini-atx/#findComment-636721
