Help w/ Custom Bios
Go to solution Solved by Raudi_,
I do realize that but what would there to be gone wrong? If I follow everything as follows it should potentially go smooth? Or is that not always the case.
Its never always the case. You need to make sure the BIOS is meant for the memory type that your card is. Flashing the wrong BIOS can brick the card and getting into the second bios is a bit of a hassle as well
So I've been looking into how to get a custom bios on a G1 GTX 970 here. Anyways, I was going to download the middle BIOS for power or whatever. So am I correct that all you would do is do what the video says and it should be fine, or did things change by now.
CPU: I5-7600k(5.1GHz)                                                       RAM: Corsair Vengeance LED(2x8GB @ 3200MHz/CAS-15)              Case: Cooler Master HAF 912
Cooler: Hyper 212 EVO                                                      Storage: 850 EVO 250GB - 2x(1TB WD Blue(Raid 0))                                   PSU: EVGA SuperNova 750W B2
Mobo: ASUS MAXIMUS IX HERO                                       GPU: G1 GTX 970        OS: Windows 10
https://linustechtips.com/topic/477088-help-w-custom-bios/
Should be how it goes, but remember if you brick your card it is your own doing and you have no warranty to cover it as flashing the custom bios voids the warrenty
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/477088-help-w-custom-bios/#findComment-6392747
https://linustechtips.com/topic/477088-help-w-custom-bios/#findComment-6392763
|King Of The Lost|
https://linustechtips.com/topic/477088-help-w-custom-bios/#findComment-6392776
Ok, I literally just got the card 2 days ago. Not going to take the risk. Thankyou for your input. I can stand the noise level.
https://linustechtips.com/topic/477088-help-w-custom-bios/#findComment-6392780
It's not that hard to flash a bios...you'd literally have to be a brain dead monkey, drooling on your keyboard to mess up the flash.  There are a couple of hundred different custom bios versions out for the G1, all the way from stock voltages and clock settings with increased power limits to extreme water cooling bios versions with 1.312v, boost disabled, increased power limits and base clocks at around 1531.
If you're interested, these guys can help you.
http://www.overclock.net/t/1573308/nvidia-gtx-900-cards-custom-bios-upon-request/970
CPU: Ryzen 1600X @ 4.15ghz  MB: ASUS Crosshair VI Mem: 32GB GSkill TridenZ 3200
GPU: 1080 FTW PSU: EVGA SuperNova 1000P2 / EVGA SuperNova 750P2  SSD: 512GB Samsung 950 PRO
HD: 2 x 1TB WD Black in RAID 0  Cooling: Custom cooling loop on CPU and GPU  OS: Windows 10
https://linustechtips.com/topic/477088-help-w-custom-bios/#findComment-6392790
a lot can go wrong
even if you follow the instructions its not guaranteed that it will work, and you could end up with a bricked card
tbh its not worth risking $300
if you want more performance buy a better GPU
https://linustechtips.com/topic/477088-help-w-custom-bios/#findComment-6392838
a lot can go wrong
It's not that hard to recover from a bad flash...even if you do trip and fall on the fail button and happen to mess it up somehow.  Plus....pretty sure the G1 has a dual bios.
I've flashed my cards probably 40 times in the last few months, trying different settings.  Do you know how many times the flash failed?  If you guessed "none", you'd be right.  lol
https://linustechtips.com/topic/477088-help-w-custom-bios/#findComment-6392860
