Custom Fan Curve - G1 GTX 970
Nasty
Can anyone recommend a custom fan curve for my G1 GTX 970... In my opinion its running pretty hot compared to others I've read. I'm currently downloading a 3DMark to test it, What is a safe temperature for it. Any help is appreciated.
CPU: I5-7600k(5.1GHz)                                                       RAM: Corsair Vengeance LED(2x8GB @ 3200MHz/CAS-15)              Case: Cooler Master HAF 912
Cooler: Hyper 212 EVO                                                      Storage: 850 EVO 250GB - 2x(1TB WD Blue(Raid 0))                                   PSU: EVGA SuperNova 750W B2
Mobo: ASUS MAXIMUS IX HERO                                       GPU: G1 GTX 970        OS: Windows 10
Fan curve depends entirely on you. How much noise you can handle vs how hot you are willing to run your card. Fool around the afterburner until you find something you like. As far as temps go, I wouldn't run it above 78-80 for too long. Technically those are safe temps but it's always better to be cautious.
Ok I just ran 3DMark and got a score of 8731, And in that time it got to 71 celcius. As I have been reading lots of people(overclocked) have been stable around 65 celcius. Just seems a bit high for a G1. Also that thing where only 1 fan or 3 spin at a time depending on the game... mine are always running even @ idle, is that correct?
8731
What's your ambient temp?
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
8731
85c even for longer periods of times is perfectly fine.  At 100% fan speeds I don't think I've ever reached near that even with Furmark.  Fan curves are all personal, just adjust it to how much noise you can take.  I usually set mine to go to 100% at around 80c and a gentle curve downwards to about 35-40c.  I use a custom BIOS so I have 0-fan as well, so my fan only starts up at around 45c or so.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
Probaly around 70 farenheit, (20 celcius)
Your temperature really isn't that high, I would just set a curve that performs well without making too much noise. With my EVGA 980ti, using a custom curve and not the BIOS fan settings dropped my temps by about 10C and I don't even hear it.
My G1 runs pretty hot too and it doesn't overclock very well at all either. Was playing tomb raider yesterday and it was hitting around 60C at stock speeds with a 25C ambient temp, not to mention the fans were really loud too, even setup a custom fan curve and it seems to just completely ignore it. Not sure what gigabyte has done to the G1 line but it seems older G1 cards were a lot better.
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
My G1 completely ignored the custom fan curve as well.. Atleast in MSI afterburner it did. I downloaded EVGA Precison X and it runs better I beleive.
