Hi,
So yesterday my UPS crashed (atleast I think so because my NAS, UPS and Server gave some errors).
It restored itself immediately but it didn't had any reason to crash it's very strange.
It's an Eaton Ellipse 1500 from 2008 or earlier.
Do you guys think I should buy a new one? It's for a business with really important data on the server and NAS.
It happened on 2015/10/30-11:52:13 (see attached log)
(I'm from Belgium so my English isn't the best.)
https://linustechtips.com/topic/476692-ups-crashed/
Can you help me with choosing one? Max load is around 800-900 watts but the site doesn't accept that... And I need one with normal plugs (CEE 7) not with IEC 320 C13
It's for 1 NAS, 1 PC, 1 small server, 1 switch, 1 router and 1 access point.
It sounds like your batteries are starting to fail due to their age but in terms of just straight replacing the unit theses would a a good choice:
http://www.apc.com/shop/be/fr/products/Onduleur-parafoudre-APC-Back-UPS-Pro-1500-230-V-CEE-7-5/P-BR1500G-FR
Most larger or business type system do use the IEC type connector however:
http://www.apc.com/shop/be/fr/products/Onduleur-Smart-UPS-APC-C-1500-VA-%C3%A9cran-LCD-230-V/P-SMC1500I
https://linustechtips.com/topic/476692-ups-crashed/#findComment-6400554
I was looking at those but the tech guy of the company our software is from recommended this one. http://powerquality.eaton.com/dotnetpages/SKUPageMobile.aspx?productID=3520&cx=3
(Eaton 5PX1500IRT)
So I bought that one I also need 8 plugs and the other ones have only 6.
But thank you for your help I really appreciate it.
https://linustechtips.com/topic/476692-ups-crashed/#findComment-6406726
