Split multiple audio tracks from video
Solved by Zambonie,
You can use Audacity and import the mp4 as an mp3 (iirc audacity can do this), then if you select the first track (by dragging your mouse from where it starts to where it end) you can go to File > Export Selection and it'll export the audio you selected. Then select the second one and export that.
edit: so pretty much like this https://www.dropbox.com/s/0ixx3on4qoxjhpr/Untitled%20255.avi?dl=0
