I just bought a Corsair Vengeance M65 FPS and realised and found a huige issue. Everrn off my PC, I always flip the switch on my power strip, so there is no power going to my pc, monitor and speakers. So when I want to turn on my computer  I flip that swith back on and press the power button on my case. But after my PC had no power running to it, the mouse does not work at all. the lights dont go on, no response, nothing. I have to plug it out and back in again. WHAT THE F**K? How is that a thing? Is it like that with every M65 or did I maybe get a flawed one? Is there maybe a way to fix this, a program that will cut power to the ,ouse for a second after the pc has been turned on, so the mouse thinks it has been replugged? I do not want to replug my mouse every timne i turn on my pc, and not cutting power to it when it is turned off is not an option too... PLease help...
CPU: Intel i7-6700K @4.8Ghz - MB: ASUS ROG Maximus VIII Ranger - RAM: 2x8GB G.Skill RipJaws V DDR4@2400Mhz - GPU: EVGA FTW GeForce GTX1080 - SSD: Samsung 850 EVO 250GB - HDD: Seagate Desktop HDD 3TB, bunch of old WD 500GB drives, old WD green 1.5TB - Case: AeroCool Mechatron - PSU: EVGA SuperNOVA G2 750 750W - Display: iijama ProLite B2712HDS 27" 1080p Display - Cooling: Enermax Liqmax II 240 - Keyboard: Corsair K70 Cherry-MX Brown - Mouse: Corsair M65 FPS Gunmetal Black - Sound: Logitech X230
https://linustechtips.com/topic/476134-crsair-m65-problem/
Thanks ill try that later today
https://linustechtips.com/topic/476134-crsair-m65-problem/#findComment-6388087
try disabling legacy USB devices in the bios. and make sure your chipset and bios are both up to date.
Tried all of that, no luck...
https://linustechtips.com/topic/476134-crsair-m65-problem/#findComment-6389437
I have not had a bios update for a year and a half, I have the ASUS SAbertooth 990FX... Could that be the source of the issue?
https://linustechtips.com/topic/476134-crsair-m65-problem/#findComment-6389470
wont know till you update it.
Check out my iCUE Guide Beta Tester for Corsair
Got a Corsair Product? Got a Question?
Feel Free to PM Me ?
https://linustechtips.com/topic/476134-crsair-m65-problem/#findComment-6392142
Sorry, I didn't use the correct phrasing.I'm saying that here is no update, I went to my mobos support site and saw that I have the newest version installed, I haven't had one because Asus didn't release one.
https://linustechtips.com/topic/476134-crsair-m65-problem/#findComment-6393479
Well, Contact Corsair Support maybe they will know whats wrong with it.
https://linustechtips.com/topic/476134-crsair-m65-problem/#findComment-6403915
I actually managed to "fix" it. I connected the mouse to a usb3.0 port and it works as it should now... Don't know why that is but oh well, at least it works as it is supposed to.
https://linustechtips.com/topic/476134-crsair-m65-problem/#findComment-6429335
