C++ help
Go to solution Solved by madknight3,
How do I check to see if they used more or less than 4 digits on the year?
I suppose you could use the obvious
if (year < 1000 || year > 9999)
edit: Just saw this
But that would allow a user to enter something like 1, or 333. I need it to be in 4 digits, so something like 0001 or 0333
You could get the input as a string instead of an int and use length().
#include <iostream>#include <iomanip>using namespace std;int main(){    int Day;    int Month;    int Year;    int Year2num;        cout << "Enter the day\n";    cin >> Day;    cout << "Enter the Month\n";    cin >> Month;    cout << "Enter the Year in a 4 digit format(XXXX)\n";    cin >> Year;        if (Day >= 1)    {        if (Month >= 1)        {            if (Year <= 1)            {    cout << "Error: The numbers can not be less than 1";                return 0;            }        }        else        {    cout << "Error: The numbers can not be less than 1";            return 0;        }    }    else    {            cout << "Error: The numbers can not be less than 1";        return 0;    }    Year2num = (Year % 100);    if (Year2num == Day * Month)        cout << "This is a magic date!\n";    else        cout << "This is not a magic date!\n";    cout << "Program complete";    return 0;}
https://linustechtips.com/topic/476118-c-help/
if(year >= 9999) /
You could also do:
if(year/10^4 != 0)
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/476118-c-help/#findComment-6380471
If you assign 0333 to an int then that int will hold the value 333 though.
int x = 0333; printf("%d\n", x); //will print 333
PSU Tier List | CoC
https://linustechtips.com/topic/476118-c-help/#findComment-6380482
if(year/10^4 != 0)
^ is XOR from what I can remember. Either use pow, but that's really not needed, or use 1e4 or even 10000.
https://linustechtips.com/topic/476118-c-help/#findComment-6380710
edit: Just saw this
https://linustechtips.com/topic/476118-c-help/#findComment-6380763
