Hi, so I'm trying to plan ahead for my possible liquid cooling build in the future. I was wondering, which would be better or is there even a difference between a reference and a custom graphics card if it's going to be liquid cooled anyway?
https://linustechtips.com/topic/476053-reference-vs-custom/
Reference cards typically have better waterblock support, though there are some aftermarket coolers that use the reference pcb, or have their own waterblocks for that specific model.
https://linustechtips.com/topic/476053-reference-vs-custom/#findComment-6379718
custom cards don't always have Water-blocks. but they also tend to have better overclocking potential, so they make better use if there is one.
use http://www.ekwb.com/configurator/ to check for water-block compatibility/availability.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/476053-reference-vs-custom/#findComment-6379726
Is it easier to find blocks for the reference ones?
Yes.
https://linustechtips.com/topic/476053-reference-vs-custom/#findComment-6379733
Seems like the better option would be to go with reference ones. I guess it just depends on the manufacturer then or something. I guess it depends on if you're overclocking or not?
Depends what what card you want to get. Most mid-high end aftermarket gpus from Nvidia (Asus Strix, Gigabyte Windforce, EVGA SSC ACX 2.0, Galax(sometimes), MSI Gaming) and some AMD R9 cards are supported. I would buy a gpu that you know for sure has a water block beforehand. But, better performance (sometimes marginal) can be gained by getting a custom pcb card and a waterblock for the same price as a reference card and waterblock.
I like good humans and good food
https://linustechtips.com/topic/476053-reference-vs-custom/#findComment-6379818
Any videos on that last part? I just want to be sure on checking sources
https://linustechtips.com/topic/476053-reference-vs-custom/#findComment-6379851
well, you wouldn't be able to get EVGA Kingpin or MSI Lightning level overclock-ability without all of those extra PCI power headers. Most aftermarket PCBs will allow you to OC better by granting more potential power. If you want to see if a particular card has a water-block just use this site: http://www.ekwb.com/configurator/
https://linustechtips.com/topic/476053-reference-vs-custom/#findComment-6379950
