This build has a lot of issues.
The PSU is bad.
There is no SSD.
The 960 is a waste of space! (Compared with the 7950/280, 285/380 and 7970/280x)
I don't know if that is super fast ram, I am not that knowledgeable with DDR4
Can you please use PCPartPicker?
I don't think the new Skylakes come with CPU coolers do they?
Other than that yes change out the PSU for something like a Seasonic 520w or something of the sorts.  Grab an SSD, like a Samsung 850 EVO for a boot drive, it's really a big boost.  The 960 4GB is a wreck of a card, I'd personally recommend the r9 380 4GB.
"You should look up common sense and add it to your vocabulary." - dougdangger 2015
http://pcpartpicker.com/user/Xenift/saved/6fzcCJ
If you really want to go with skylake, here it is.
I don't recommend skylake, this is because the motherboards are more expensive, ram is also more expensive for you.
R9 380 is a heck alot better in my opinion so i would go with it.
-EDIT-
No CPU cooler haha xD.
Add CM EVO 212 23 bucks
I believe that the K series processors do not come with CPU coolers (due to the fact that you know, OC with a stock cooler yada yada yada), though im not sure about the locked processors.
Quote me if you want me to see your message. Like my post if it helped. Click "Show More" to see things that I use.
Desktop (2014): CPU: Intel Core i5 4690k @ 3.50GHz | GPU: MSi GTX 970 Gaming 4G | Motherboard: MSi Z97 Gaming 5 | RAM: 2x4GB G.Skill RipJaws X 1600MHz + 2x4GB HyperX Black 1600MHz | SSD: Samsung 750 Evo 120GB | HDD: WD Black 1TB | Cooler: Cooler Master Hyper 212x | PSU: Corsair VS650 | Case: Cooler Master Elite 431 Plus | OS: Windows 10 Home
Laptop (2017): Model: Asus UX310U
Peripherals: Monitor: Samsung S24D300 OC@75Hz + Viewsonic XG2401 (144Hz) | Mouse: Logitech G305 | Keyboard: Razer Blackwidow Chroma V2 | Headset: HyperX Cloud Core | Speakers: Logitech Z333 | Additional: Logitech G29
Mobiles: Samsung Pixon (2010-2012) | Samsung Galaxy Ace (2012-2013) | Samsung Galaxy S3 (2013-2016) | Samsung Note 4 (2015)(Lost) | Samsung Galaxy S7 (2016-2019) | Samsung Galaxy S10 (2019 - Current) | Additional: ASUS Zenwatch 2 (2016)
The PSU is bad.
There is no SSD.
http://pcpartpicker.com/p/8rwCxr
Right now tight budget. SSD will be added in a few months
The Averix Cores look awesome. The best looking Ram IMO! (Not because I own them)
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  ($205.99 @ SuperBiiz)
Motherboard: Asus H170-PRO ATX LGA1151 Motherboard  ($108.99 @ B&H)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card  ($188.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($49.99 @ Micro Center)
Optical Drive: LG GH24NSC0 DVD/CD Writer  ($13.89 @ OutletPC)
Total: $743.21
Generated by PCPartPicker 2015-10-29 07:20 EDT-0400
Total: $743.21
thanks ... I ll consider this build.
I ll update when I buy it within a week
with an IPS monitor in the total price
Motherboard: Gigabyte GA-B150M-D3H DDR3 Micro ATX LGA1151 Motherboard  ($68.40 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  ($47.89 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($40.50 @ SuperBiiz)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($183.98 @ Newegg)
Case: Deepcool TESSERACT SW ATX Mid Tower Case  ($35.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ NCIX US)
Monitor: Acer H226HQLbid 60Hz 21.5" Monitor  ($109.99 @ Newegg)
Total: $756.62
Generated by PCPartPicker 2015-10-29 08:56 EDT-0400
The site has changed....
