So im going to build using the Silverstone Gd09 and am thinking of using the corsair h80i or h80gtx,  possibly the 55 as well, im using a regular atx mother board, and am wondering if it will fit in the case, i know there are 120mm fan mounts so it should fit, but i mean clearences
Its a Championship not a Belt!
https://linustechtips.com/topic/474779-will-this-cooler-work/
hey, I tried to give you a solution. I saw your post in recent topics so I thought I could give you a hand.
saying, check pc part picker which i already did, is not a solution, a solution would be saying, use this instead.
https://linustechtips.com/topic/474779-will-this-cooler-work/#findComment-6362072
You are able to fit a 120mm rad next to your PSU. However I do think with an AIO loop like the H80i the tubing is to short to reach the CPU.
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/474779-will-this-cooler-work/#findComment-6362565
